It is currently Fri Sep 21, 2018 8:23 am
Sheetcam questions
Post your questions or tips on SheetCam software in this topic.
Spitterkat
Sheetcam questions
Postby Spitterkat » Sun Dec 03, 2017 3:17 pm
Hi guys,
I'm pretty new to sheetcam and when I import a multi part drawing from autocad, all of the parts are bound together and I cant move them across for better nesting, also is there an auto nesting feature? If I want to increase the number of parts being nested do I just ctrl c / ctrl p? or is there a way to enter a given value?
steel 35
Re: Sheetcam questions
Postby steel 35 » Sun Dec 03, 2017 4:12 pm
Arclights videos cover all of theses and (much) more.
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
SeanP
Postby SeanP » Sun Dec 03, 2017 4:17 pm
Sorry there is no auto nesting, you can array parts with gap and spacing dimensions, that works well in nesting mode right click and choose array parts.
You can sometimes break up a multi part file as below, I have had some files it doesn't work on though.
Powermax 45 with Duramax torch.
R-Tech 210 Tig, Jasic 250 mig
Sheetcam, Scanything, Coreldraw X8, Solidworks
Table build gallery
tcaudle
Postby tcaudle » Sun Dec 03, 2017 5:07 pm
Its better to bring in one part at a time if you want to do nesting or move the parts individually/ I don't know if you can export part of a drawing (selected items) like you can in some of the drawing programs/ Its better to do nesting on multi part cuts in SheetCAM where you can put different parts on different layers and cut them using different rules or tools if you want. You might try using Inkscape to import the big DXF then break it apart and export separate objects as SVG direct to SheetCAM. You might have to try older DXF file types to get something Inkscape can open.
tnbndr
Postby tnbndr » Sun Dec 03, 2017 7:01 pm
I draw the sheet size as a rectangle and nest the parts in Autocad, then save as 2000dxf and import into Sheetcam. Assign tools and process.
LDR 4x8, Scribe, DTHCIV
PM45
Miller 211
RW 390E Slip Roll
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
ggeh
Postby ggeh » Fri Dec 08, 2017 10:13 am
Hi guys
Is it possible to bring mutable drawings in sheetcam so I can nest them on one sheet instead of individual one at a time or do I have to do that in my cad program. When I bring a new drawing in sheet cam goes to a new screen with the latest import and doesn't show the drawing before that.
Thanks, Gary
Les Newell
Postby Les Newell » Fri Dec 08, 2017 10:28 am
Instead of just going to file->import drawing, use File->new part. Now import your drawing into that new part.
ggeh
Postby ggeh » Fri Dec 08, 2017 1:35 pm
Les Newell
Well that was easy enough. Thanks for the quick reply and help on something so basic that I should know by now. I been using sheetcam for more than a year now and didn't know how to do this. Les Newell your the best, thanks again Gary
Return to “SheetCam”
