It is currently Fri Jun 22, 2018 6:53 am
Tip Size Default value 45 amp
Post your questions or tips on SheetCam software in this topic.
exapprentice
Postby exapprentice » Thu Nov 16, 2017 5:09 am
Hi everyone
just asking if there is a way of editing / changing the "Tip Size" from the default 45 :?:
I have tried to edit the "PLASMA TOOL" where it states "Tip size - amps" but it always seems to defaults back to 45 has anyone else noticed this or found a way of changing the value :?: :?:
Best Regards to all
Exapprentice :D
(Pete)
Re: Tip Size Default value 45 amp
Postby djreiswig » Fri Nov 17, 2017 10:55 am
I think the tip size setting just displays in the code. I don't believe it actually does anything as far as setup. One of the posts has an error where two numbers are swapped and it won't allow the setting to stick.
sphurley
Postby sphurley » Fri Nov 17, 2017 5:16 pm
Platform CNC Plasma table
CandCNC Ethercut IV DTHC
Hypertherm 85/CPC/RS485
Miller 350P
Miller Dynasty 280DX
Return to “SheetCam”
