It is currently Sun Aug 19, 2018 10:09 am
How do you program hole pierce on start points?
Post your questions or tips on SheetCam software in this topic.
alonzo83
Postby alonzo83 » Sun Nov 12, 2017 11:41 am
Yesterday I got into an issue of slag getting in the way after the hole pierce on heavy plate using the oxy propoliene
The plate was 1-3/4 thick the profile of the cut was a 1"x 6" slot, so there was a good amount of slag getting in the way of the cut.
I ended up manually stopping the cut and moving onto the next pierce point 12 times then homing the torch knocking off all the slag . Then re running the program and aborting the preheat twenty or so seconds into the preheat and cutting the profile.
is there a means of setting up a layer in sheet cam that will allow me to make all my pierces on the start points, then move to 0,0 and let me knock off all the slag and reduce my pre heat time before beginning the actual cutting? I watched a drill function being used on hole points but I could not make it work on start points.
Thank you for any advice you can offer.
Alonzo
dynatorch xls, hypertherm 125 generator, Oxy propylene torch, multiple lathes, mills and saws.
Gamelord
Re: How do you program hole pierce on start points?
Postby Gamelord » Sun Nov 12, 2017 2:01 pm
You can try wiggling the torch as it pierces, that may help lessen the slag. Not sure if that would be possible with an oxy setup.
Les Newell
Postby Les Newell » Mon Nov 13, 2017 7:03 am
There isn't a spcific function for this but there are a few workarounds. If you can identify where the start points need to be on your drawing you can draw circles at those points. Puth the circles on a different layer. You can now use the drill function to pierce those holes. This can be tedious to set up, especially if you have lead ins.
Another possibility is to use a modified post processor. This would ignore the cut path and just pierce. If you tell me what post you are using I can do that for you.
As Gamelord sugests a wiggle pierce may also help.
alonzo83
Postby alonzo83 » Mon Nov 13, 2017 10:52 am
Thank you for the replies.
I am using dynatorch xls.
I will try the wiggle but the modified post processor would be the most ideal solution.
Alonzo
Les Newell
Postby Les Newell » Mon Nov 13, 2017 11:20 am
I don't think I have that post. Could you send me a copy.
alonzo83
Postby alonzo83 » Mon Nov 13, 2017 12:09 pm
I can try, not sure how.
Alonzo
Les Newell
Postby Les Newell » Mon Nov 13, 2017 1:50 pm
In SheetCam Options->machine->post processor->Edit post. In the post editor File->Save as. Save it in any convenient folder. You can now post it on the forum or email it to me.
alonzo83
Postby alonzo83 » Tue Nov 14, 2017 9:26 am
Can you pm me your email?
Plasma spider is telling me it is an invalid file extension.
Many thanks.
Alonzo
Return to “SheetCam”
