It is currently Thu Jul 19, 2018 7:33 am
sheetcam problem
Post your questions or tips on SheetCam software in this topic.
Fawad Afzal
sheetcam problem
Postby Fawad Afzal » Sun Jul 02, 2017 8:27 pm
sheetcam not working properly when i do simulation it says your feed rate is 0 and when i going to make g codes its file is 0byes
tnbndr
Re: sheetcam problem
Postby tnbndr » Mon Jul 03, 2017 7:45 am
Go to the Help/About and make sure it is a licensed version.??
LDR 4x8, Scribe, DTHCIV
PM45
Miller 211
RW 390E Slip Roll
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
tcaudle
Postby tcaudle » Mon Jul 03, 2017 11:56 am
A license is not required to do the first 150 lines of code unless its a pirated version. So you should get SOME code If you have operations defined with a tool and feed rates and have the contours on the layer associated with the operation. You should see the blue wider toolpaths as you define the operations. You have to select the correct POST processor to get code.
Fawad Afzal
Postby Fawad Afzal » Fri Jul 21, 2017 6:12 pm
thanks my problem is solved
Return to “SheetCam”
