It is currently Sat Aug 18, 2018 6:37 pm
How to offset cut path using Tracker software
Post your questions or tips on Tracker software in this topic.
FreeDXF.com
Postby FreeDXF.com » Wed Nov 11, 2009 7:38 pm
Does anyone out there know if how you can offset your cut paths using the command and cut software? Any information or suggestions would be greatly appreciated. Thanks JH
jim
Re: how to offset cut path using command & cut software
Postby jim » Thu Nov 12, 2009 7:21 am
Hey Jason
I have command and cut can you explain a bit more what you are trying to do.
Jim(murals in metal)
nuno115
Re: How to offset cut path using Tracker software
Postby nuno115 » Tue Feb 19, 2013 10:29 am
I also have Tacker software and it does not come with those features (I wish)
I draw my parts on AutoCad and always add 0.04 to the outside edges and subtract 0.04 from holes.
This is for a kerf of 0.08, if more just divide it by 2.
If I was to cut a 6"x6" I would make it 6.04"x6.04"
and if it is a hole of 1" diam. I would make it 0.96"
In inside shapes, just subtract 0.04 on each side.
Team Tracker
Postby Team Tracker » Thu Feb 28, 2013 10:37 am
The ProTable software package automatically adjusts for the kerf width, automatically add lead in's, automatically resequence's the cut order and cut direction, as well as does full auto nesting. Nuno, you have our economical Nitro system which does not come standard with these automatic features however these tasks can be completed manually with ease, it just takes a little longer. You can upgrade your Nitro system if you like at anytime if you feel these automatic features are beneficial for you now and worth the cost. Please call me or PM me if you would like more information.
Regards
Reid T
Tracker CNC
Technical Support
http://www.trackercnc.com
1-800-590-7804
1-800-590-7804
Cool Metal Works
Postby Cool Metal Works » Wed Jul 02, 2014 5:37 pm
Reid.
What does this said upgrade cost for someone that does not have to pro setup?
Team Tracker
Postby Team Tracker » Wed Jul 09, 2014 11:17 am
CNW Contracting wrote:Reid.
I have sent you a message with some options that may be of interest to you. Let me know if you have any questions.
1-800-590-7804
radicalrescue
Postby radicalrescue » Fri Jun 26, 2015 12:16 am
reid t is there any way to optimize the cut path
Reid T wrote:The ProTable software package automatically adjusts for the kerf width, automatically add lead in's, automatically resequence's the cut order and cut direction, as well as does full auto nesting. Nuno, you have our economical Nitro system which does not come standard with these automatic features however these tasks can be completed manually with ease, it just takes a little longer. You can upgrade your Nitro system if you like at anytime if you feel these automatic features are beneficial for you now and worth the cost. Please call me or PM me if you would like more information.
Regards
Reid T
Tracker CNC
Technical Support
1-800-590-7804
Team Tracker
Postby Team Tracker » Fri Jun 26, 2015 9:13 am
radicalrescue wrote:reid t is there any way to optimize the cut path
What do mean by optimize the cut path?
1-800-590-7804
radicalrescue
Postby radicalrescue » Fri Jun 26, 2015 9:44 am
thanks for the reply again,,ok i am going to cut a 4x4 sheet ill attach file .when it starts it travels to the far side of the plate makes a cut then moves across to the other side makes a cut then all the way across the plat to another spot cuts ...is there a way to start just off home an cut from a .b.c...travel time @120 thanks ron
Team Tracker
Postby Team Tracker » Fri Jun 26, 2015 9:51 am
OK, you want to re-order your cut sequence. I am guessing you purchased this machine used and do not have an operator manual. If that is the case please send your email address by Private Message ( I would not post your email in this thread) and I will forward a guide to you that will show you how to do these operations.
1-800-590-7804
radicalrescue
Postby radicalrescue » Fri Jun 26, 2015 6:08 pm
i pm u with the e mail my system command n cut mt 3.13.14 thanks
Return to “Tracker Software”
