It is currently Tue Aug 14, 2018 10:19 am
Memory Upgrade
Post your questions or tips on Tracker software in this topic.
smokez1
Memory Upgrade
Postby smokez1 » Wed Nov 21, 2012 8:04 pm
Does anyone know what type of memory Tracker CnC computer uses?
I want to add memory.
thanks for any info
Team Tracker
Re: Memory Upgrade
Postby Team Tracker » Sat Dec 01, 2012 7:01 pm
smokez1, it would depend on the date of manufacture. All Tracker systems come with a factory configured, onboard computer built into the Command Center to make it easy for the end user to setup and get started quickly and with confidence. As computers change we change with them. If you reply with serial number or manufacture date I can determine what RAM will be needed. I will mention that adding more RAM will not improve the performance of the system and that the onboard computer is far more powerful than what is required for this application.
1-800-590-7804
Return to “Tracker Software”
