It is currently Sat Jul 21, 2018 11:36 am
cut and command unresponsive
Post your questions or tips on Tracker software in this topic.
Predeorb
Postby Predeorb » Thu Jul 05, 2012 11:24 am
HMMM....
When editing a plt file in cut and command, typically I use the join option which greatly reduces the number of objects. For example if I have 900 objects (lines) it would reduce the file to about 130 individual objects. I used coral to design the sheet and grouped them within corel but when they are imported into cut and command the grouping is not recognized. Is there something I am missing? The file that I am currently trying to join freezes cut and command. :?:
Nevermind....Justin from Tracker took care of things....I am not sure how they do it!!! :P Looks like it was an operator error. :?
Thank you for the quick response and the help Tracker.
Pete
Team Tracker
Re: cut and command unresponsive
Postby Team Tracker » Thu Jul 05, 2012 12:10 pm
Hey Pete, glad to see your problem resolved so quickly. He always seems to beat me to the solution.
Regards
Reid T
Tracker CNC
1-800-590-7804
kkustomz
Postby kkustomz » Mon Jan 29, 2018 10:55 pm
Could you share the help that fixed your issue, I very often have the same issue, Corel shows the nodes connected, then when I open it in command and cut, I have all these individual lines.
Return to “Tracker Software”
