It is currently Sun Sep 23, 2018 8:38 am
tracker software
Post your questions or tips on Tracker software in this topic.
GWS.Arkansas
tracker software
Postby GWS.Arkansas » Sat Sep 03, 2011 6:05 pm
Well Thank You
Team Tracker
Re: tracker software
Postby Team Tracker » Mon Sep 05, 2011 6:40 pm
The difference between the V3 and V5 software is the way it communicates with the controller. V3 uses the LPT port and V5 is our latest and communicates via Ethernet. I looked up your history and see you are running a non-shielded Ethernet cable and that a shielded replacement is on it's way. Justin has you operating on V3 using the LPT port in the meantime.
You can still obtain the same cut quality you are accustomed to with the V5 software, V3 is not the reason you are getting rough edges. I know its Labour day long weekend but we offer 24/7 technical support so just give us a call so we can check your V3 settings and get you on the right track anytime.
1-800-590-7804
WSS
Postby WSS » Sun Sep 18, 2011 12:59 am
Reid T wrote:I know its Labour day long weekend but we offer 24/7 technical support so just give us a call so we can check your V3 settings and get you on the right track anytime.
Service with a smile? Not many out there offering that. Keep up the good work.
WSS
Last bumped by GWS.Arkansas on Sun Sep 18, 2011 12:59 am.
Return to “Tracker Software”
