It is currently Tue Aug 14, 2018 2:36 am
circles still not circles
Post your questions or tips on Tracker software in this topic.
Cbrbarnes
Postby Cbrbarnes » Tue Jun 09, 2015 6:50 pm
I'm running a current version of Command n Cut and doing my line work in Corel X7. I'm trying to create a 16" circle on my Tracker table. I've converted the ellipse into curves and everything looks good and smooth in Corel. Once in Command n Cut the circle becomes a series of straight lines again. Anybody dealt with this or have any ideas? I'm fresh out of things to try to correct this? Thanks
Corfabrication
Re: circles still not circles
Postby Corfabrication » Tue Jun 09, 2015 7:30 pm
i dont know how to help you with that, but here is a 16" circle if it helps.
Team Tracker
Postby Team Tracker » Wed Jun 10, 2015 10:02 am
Cbrbarnes wrote:I'm running a current version of Command n Cut and doing my line work in Corel X7. I'm trying to create a 16" circle on my Tracker table. I've converted the ellipse into curves and everything looks good and smooth in Corel. Once in Command n Cut the circle becomes a series of straight lines again. Anybody dealt with this or have any ideas? I'm fresh out of things to try to correct this? Thanks
Your export settings are incorrect which is why your circles are coming out segmented. I know you purchased your Tracker table 2nd hand and have a fresh version of Corel installed so give me a call and we can go over your settings.
1-800-590-7804
Cbrbarnes
Postby Cbrbarnes » Thu Jun 11, 2015 8:11 pm
I appreciate that. I've got a new controller and new Corel software. The only remaining pieces of the old table are the table itself and the steppers moving the head around. I will contact you soon, thank you very much
Cbrbarnes
Postby Cbrbarnes » Tue Jun 16, 2015 5:44 am
Thanks Reid, I called in and got it all straightened out. It's been a real pleasure dealing with Tracker
Return to “Tracker Software”
