vinyl plotter and mach
HammerDownJustin
Post by HammerDownJustin »
Just curious has anyone ever used Mach 3 to run there vinyl plotter? My old cutter program was lost many years ago. I can design with the Corel but don't have a cam program to run it anymore. So the thought was in the back of my head.
Miller 251 Mig
kbenz
Re: vinyl plotter and mach
Post by kbenz »
wouldn't you still need something to generate the g code?
CandCNC
Mach3
Draftsight
Hypertherm 65 machine torch
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Gamelord
4.5 Star Member
4.5 Star Member
Post by Gamelord »
This may work for you:
http://www.signtools4.com/
I also found info here that says you can cut directly from Corel. Haven't actually done this myself but maybe it will help.
http://forum.uscutter.com/index.php?/to ... coreldraw/
I have used a vinyl cutter on my table no problems (Sean P has done vinyl work too) I just run what I want to cut through SheetCam using a router type Post Processor. That gives Mach a G-code to run I have a floating knife and start by dropping the knife on the vinyl and drop about 0.050" more and zero the Z dro. The tell mach to move Z up to about 0.500" and start my G-code, router tool set to cut the only layer at 0.003".
Samples of things I cut and 2 different drag knifes I copied Sean P floating holder design :D
HammerDownJustin
Thank you for the great help. Will resource them all and might just make a tool holder for the table and a clean mounting surface..lol
Miller 251 Mig
Return to “Mach3 & Mach4 CNC”
