It is currently Tue Sep 25, 2018 1:30 pm
vinyl plotter and mach
Mach 3 CNC from Artsoft questions or tips can be posted to this forum.
HammerDownJustin
Postby HammerDownJustin » Thu Aug 11, 2016 2:21 pm
Just curious has anyone ever used Mach 3 to run there vinyl plotter? My old cutter program was lost many years ago. I can design with the Corel but don't have a cam program to run it anymore. So the thought was in the back of my head.
Miller 251 Mig
kbenz
Re: vinyl plotter and mach
Postby kbenz » Thu Aug 11, 2016 4:29 pm
wouldn't you still need something to generate the g code?
CandCNC
Mach3
Draftsight
Hypertherm65 machine torch
Millermatic 210
Spoolmatic 30a w/ WC-115a
Miller Bobcat 225
Gamelord
Postby Gamelord » Thu Aug 11, 2016 4:32 pm
This may work for you:
http://www.signtools4.com/
I also found info here that says you can cut directly from Corel. Haven't actually done this myself but maybe it will help.
http://forum.uscutter.com/index.php?/to ... coreldraw/
Torchmate CAD
Postby acourtjester » Thu Aug 11, 2016 5:24 pm
I have used a vinyl cutter on my table no problems (Sean P has done vinyl work too) I just run what I want to cut through SheetCam using a router type Post Processor. That gives Mach a G-code to run I have a floating knife and start by dropping the knife on the vinyl and drop about 0.050" more and zero the Z dro. The tell mach to move Z up to about 0.500" and start my G-code, router tool set to cut the only layer at 0.003".
Samples of things I cut and 2 different drag knifes I copied Sean P floating holder design :D
Everlast PM 256 tig
HammerDownJustin
Postby HammerDownJustin » Fri Aug 12, 2016 2:12 pm
Thank you for the great help. Will resource them all and might just make a tool holder for the table and a clean mounting surface..lol
Miller 251 Mig
Return to “Mach3 CNC”
