It is currently Tue Sep 25, 2018 1:16 pm
new problem with Mach
Mach 3 CNC from Artsoft questions or tips can be posted to this forum.
vittonej
Postby vittonej » Tue Jun 14, 2016 10:16 pm
When I make a cut, in sheet cam it shows a cut path, but when it gets to Mach and starts a cut it starts out about 3 inches before the part, not sure why. It should be a problem with sheet cam but I don't see it in sheet cam, but once I run it starts the cut with a 3 inch lead in, never seen this before till the other day. I have try to change the operation like shortest cut or cut inside first doesn't make a difference, but I don't see it in mach
sphurley
Re: new problem with Mach
Postby sphurley » Tue Jun 14, 2016 11:13 pm
Post the start of the gcode, lets see why.
Platform CNC Plasma table
CandCNC Ethercut IV DTHC
Hypertherm 85/CPC/RS485
Miller 350P
Miller Dynasty 280DX
vittonej
Postby vittonej » Wed Jun 15, 2016 7:20 am
this is were the code would start to make the lead in
vittonej
Postby vittonej » Wed Jun 15, 2016 7:24 am
this would be the start and the first lead in cut
vittonej
Postby vittonej » Wed Jun 15, 2016 7:36 am
I am having trouble attaching, but this would be the first lead in and the start. I get a caution sign when attaching photos either from my phone or computer???
sphurley
Postby sphurley » Wed Jun 15, 2016 11:04 pm
Did you make the lead in 3inches instead of 3/10s of an inch?
Miller 350P
vittonej
Postby vittonej » Sat Jun 18, 2016 12:18 am
Up date of my troubles, I struggled for almost 3 days trying to figure this out, it got a lot worse before it finally got better, it went from lead in troubles to taking the part and splitting it up and the distance was off the lead ins were wrong, just one thing after the next. it would also take a 12 inch part and make it 6 inches. Finally I called Westcott Plasma, and talked to Brian, Their tech support is awesome, After talking to them we came to the consensus that I should do one of two thing,s dump MACH out of the computer, and start over, or even look at a new rebuild computer to load the program in, I dumped all the programs out and did a reinstall on the computer went back through all the step to load the software, took right off. no errors, I would have been beating my head for the next week. As an instructor of CNC plasma and Flow Water Jet, this was one of my more challenging problems, I run Plasma Cam, TorchMate, plus Flow water jet, at work and I own a Precision Plasma for home use, this one had me stumped. It just kept losing one feature after the next.
Jay
Ribbedgiraffe
Postby Ribbedgiraffe » Sat Jun 18, 2016 1:02 am
Glad you got it resolved!
Still learning!
4x8 homebuilt w/Water table - Hypertherm Powermax 45 (Machine torch)
13" Metal Lathe
7x12 Meta lathe
1-1/2hp Milling machine
Hobart 190 Wire feed
Hobart EZ-Tig
Elcheapo powdercoating gun W/Autoclave oven converted for powdercoating.
WyoGreen
Postby WyoGreen » Sat Jun 18, 2016 4:24 pm
Don't you just love computer problems? And people think we should have computers driving our cars. :shock:
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
CNC Router table
Return to “Mach3 CNC”
