For some reason mach3 is just stopping in the middle of a cut. No error message of anything.
I don't know if it has anything to do with it, but I had an issue where I had to hit the stop button.
Maybe coincidence but since then it stops on every thing at random spots on the Gcode.
I've tried gcode that I know has always worked fine
Any ideas what that might be about?
Thanks Kindly
Dan
Mach just stops mid cut
Re: Mach just stops mid cut
You may check the in the general Logic configuration to see what the input signal debouncing/noise rejection is set at. I have mine set about 5000 each if there in no value in these you will get no error stops.
I'll check that out!
Thanks!!
Thanks!!
