Hi,
I would like to use a pneumatic activated scriber on my table.
(working with sheetcam TNG and Mach3 Plasma)
Does anyone know the setup for that ???
Felix
How to setup scriber...
Re: How to setup scriber...
You can go back through the posts here and find how to set up SheetCam and Mach it depends on your electronics as to what post processor you use.
The main thing with the scribe is you want the tip to just touch the metal so the movement of the scribe punches the metal. If you have to much down pressure touching the metal it will drag and skip when it moves.
