It is currently Sun Jun 17, 2018 11:36 pm
$5 if someone with the Advanced Design Software can convert my PCM file to DXF
Post your questions or tips on Plasmacam software in this topic.
Texan95
Postby Texan95 » Thu Oct 12, 2017 4:19 pm
Howdy!
I'm a hobbyist who uses the basic PlasmaCAM DesignEdge at my college. I wanted to convert my PCM file to DXF but I just found out you need the $1000 Advanced Design Software update to do so :/
I really need my file converted and am stuck at an impasse. I would pay someone $5 over PayPal if they can pop my file into Advanced Design Software and export it as a DXF file.
Thanks and I hope I'm not violating any forum rules by offering to pay.
Re: $5 if someone with the Advanced Design Software can convert my PCM file to DXF
Postby jimcolt » Fri Oct 13, 2017 10:17 am
You can convert to a .dxf with your software, I'm sure. Open up your software, open up your desired PCM drawing file, under the file tab choose export......and send it to any folder you want....it will be in .dxf format if you use the export function. Jim Colt
rdj357
Postby rdj357 » Fri Oct 13, 2017 11:29 am
jimcolt wrote:You can convert to a .dxf with your software, I'm sure. Open up your software, open up your desired PCM drawing file, under the file tab choose export......and send it to any folder you want....it will be in .dxf format if you use the export function. Jim Colt
That requires the Advanced Design upgrade Jim, it is not an option in basic design. I've private messaged him and for anyone else that needs it done they can contact me as well. I'm usually at my computer off and on during the day and can send them back pretty quick. It's one of those features like metric units that should be included in all levels at no additional charge.
Robert Johnson
FourNinety Creations
PlasmaCam 5x10
Snap-n-Cut Mount
PM 65 w/ Mini Machine Torch
Router Attachment/DW611
VCarvePro & Photo VCarve
SpectraCoat Powder Coat System
7'x7'x10' DIY Powder Coat Oven
Return to “Plasmacam Software”
