How do I get downloaded dxf files to Plasmacam?
shinertx
Post by shinertx »
How do I go about downloading files from the forum to my plasma cam, I do have the design edge software! I am new to all of this, and there are some great files on here any help would be great full thanks.
Samson 5x10
Designedge software
Hypertherm Powermax 65
Hypertherm powermax 380
Thermodynamics cut master 85
Jet 4' box & pan break
Eastwood Powder coating guns.
Buzzard Gut
Re: Down load dxf files to plasmacam
Post by Buzzard Gut »
Click on the download attach. Say OK to down load. This will put it in your download files, then go to your down load files ( should be an arrow in the upper right hand corner). Double Click on the file and open it (my computer ask me if I?m sure I want to do this. ) It will first tell me it cannot recognize the file, just hit OK. It should open up Plasmacam , then go to file and import ,then click on the file. And that should bring up the file. You will need to remember your file name.
Hopefully this works for you.
Bob
The older I get, The better it was!
otisa2007
Post by otisa2007 »
under the file tab in plasma cam use the import and the designedge will open it be shure to check your cut paths before trying to cut my designedge sometimes gives me some crazy cut paths when i import dxf files
shinertx
Post by shinertx »
Buzzard Gut wrote:Click on the download attach. Say OK to down load. This will put it in your download files, then go to your down load files ( should be an arrow in the upper right hand corner). Double Click on the file and open it (my computer ask me if I?m sure I want to do this. ) It will first tell me it cannot recognize the file, just hit OK. It should open up Plasmacam , then go to file and import ,then click on the file. And that should bring up the file. You will need to remember your file name.
Bob
Bob, thank you so much for the info I will give it a shot when I get back to the shop. thanks Robert
Samson 5x10
Designedge software
shinertx
Post by shinertx »
otisa2007 wrote:under the file tab in plasma cam use the import and the designedge will open it be shure to check your cut paths before trying to cut my designedge sometimes gives me some crazy cut paths when i import dxf files
ok, let me see first if I can get to the plasma cam thanks for the info. Robert
Samson 5x10
Designedge software
Buzzard Gut
I missed that part....I don't have the designedge software :D I'm still old fashion.
Joe Jones
Re: How do I get downloaded dxf files to Plasmacam?
Post by Joe Jones »
You can also right-click on the .dxf file itself and use "OPEN WITH" or "OPEN USING." Point it to DesignEdge and it will take care of importing it correctly.
Franklin, KY., USA
Samson 510 & 4x4
CreatBot D600 PRO 3D Printer
12 Lasers
FREE DesignEdge Training!
