It is currently Thu Jul 19, 2018 3:39 pm
letter not linking in plasmacam
Post your questions or tips on Plasmacam software in this topic.
krymis
Postby krymis » Fri Sep 01, 2017 11:01 am
I am having a hell of a time trying to figure out the new design edge software. I need to see if someone can explain to me why the L letter will not link to the rest of the drawing.
cfl.pcm
rdj357
Re: letter not linking in plasmacam
Postby rdj357 » Fri Sep 01, 2017 1:13 pm
There is a spot where the path is not quite lined up and overlaps. I attached a couple pictures that should help you see it. To find it, I used the break tool (K) to break the path in a random spot. Then when you click on one side or the other of where you broke it, it will turn green since you've selected it and the spot where it has a break will show up (the path next to it will be white as it is not selected) and you can zoom in to see why.
Hope that helps!
Robert Johnson
Learn Plasmacam Website
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
krymis
Postby krymis » Fri Sep 01, 2017 2:22 pm
ok that makes sense. Now how can I move that to connect? Thank you very much for the instruction.
rdj357
Postby rdj357 » Fri Sep 01, 2017 6:15 pm
I had a bunch of stuff typed out and it didn't make much sense when I read it so I made this. Might be a little better I hope lol
Design Edge Finding Path Problems - YouTube
Robert Johnson
krymis
Postby krymis » Fri Sep 01, 2017 10:38 pm
Man thank you for taking the time to make that. little fuzzy just because I am only 2 days into learning the software. I cant thank you enough.
rdj357
Postby rdj357 » Fri Sep 01, 2017 10:50 pm
No problem! Pm me if you want I'll send ya my phone # to text or call if I can help.
Robert Johnson
Return to “Plasmacam Software”
