It is currently Sun Aug 19, 2018 10:10 am
nesting error
Post your questions or tips on Torchmates software in this topic.
kbenz
nesting error
Postby kbenz » Tue Mar 27, 2012 7:19 pm
trying to nest some 11ga. keep getting an error "sheet:signblank0 size too small" any ideas?
[email protected]
Re: nesting error
Postby [email protected] » Thu Apr 19, 2012 9:59 pm
If memory serves me right i believe i have ran into this issue and i just change the method of making path - breaking path - before nesting parts. make sure each part is individually one path. so if you have a square with 4 holes in it make that one path. then if you want to duplicate it from there say ten times you should show 10 items. keep it that way do your nesting function once its nested then select all of them and make it one path then continue onto your create tool path etc... also make sure and save often i have noticed the tmc auto nesting likes to crash and when you have gaps and your trying to manually fill the small spaces with random items and 10 minutes later of jogging parts around to fit where the program doesnt think they will it will crash. good luck let me know if this helped
