It is currently Fri May 25, 2018 5:04 am
Stretching / Duplicating a complex shape
Post your questions or tips on Torchmates software in this topic.
No Class
Postby No Class » Mon Nov 14, 2016 8:11 pm
I am hoping someone can help me with a something I am struggling with. I have a complex shape (attached) that I am trying to make a layered sign from. I would like to have a uniform "border" around the outside of 2 inches. With a standard oval or rectangle or any other standard shape it is relatively easy. This shape however when scaled up or down doesn't leave a uniform "border" around the perimeter. Short of moving each node individually in the areas that are not cooperating I am stumped. This is not the first time I have run into this problem. Ironically it is not allowing me to attach a .CDL file so I have created an online cutpath and attached it as a .dxf
Thanks in advance.
No Class
Gamelord
Re: Stretching / Duplicating a complex shape
Postby Gamelord » Mon Nov 14, 2016 8:46 pm
IF you are using Corel Draw or Inkscape, you would want to use the Contour tool. This will do what you want. This topic may help.
http://www.plasmaspider.com/viewtopic.php?f=49&t=14750
Torchmate CAD
No Class
Postby No Class » Tue Nov 15, 2016 6:06 pm
Thanks Gamelord. I was hoping Torchmate CAD had a function to do that. Maybe its time to invest in Corel Draw.
No Class
Postby No Class » Tue Nov 15, 2016 6:55 pm
Well I think I have a solution. I went and created another tool in my tool library and set the tool diameter at 2.5" When I create male tool path it shows a perfect contour around the perimeter. I am going to try it out tomorrow.
jakedog
Postby jakedog » Mon Dec 05, 2016 12:27 pm
messge me, there is a simple way to that in torchmate
