It is currently Wed Sep 19, 2018 7:08 am
cutting problem
Post your questions or tips on Torchmates software in this topic.
cutting problem
Postby acourtjester » Fri Nov 20, 2015 4:54 pm
HI
I was asked about a problem that I have no idea what the answer is and an asking for help here.
I supplied a guy with many DXF files and he said when they tried to cut them on a torchmate system it cut the lines twice.
Since I use SheetCam and Mach 3 I am lost as to what is going on. :oops: :shock:
Thanks Tom
Everlast PM 256 tig
Gamelord
Re: cutting problem
Postby Gamelord » Fri Nov 20, 2015 9:58 pm
Hard to say without having the files to look at, but he may be using the torchmate program to create his toolpaths and then exporting the entire program out to torchmate cad to cut. If he does this without deleting the original drawing (which leaves only the toolpath to export) he may be cutting both the original drawing and then cutting the toolpath.
This may be his issue.
Re: cutting problem
Postby acourtjester » Sat Nov 21, 2015 7:49 am
Thanks for the reply I will send this on to the guy.
The file has been used by myself and other many times I used sheetcam for the cut routine.
have fun and a Happy thanksgiving
Tom
Everlast PM 256 tig
rbealer
Re: cutting problem
Postby rbealer » Sat Dec 02, 2017 3:31 pm
Just had this same problem, found this thread then found another possible answer. This worked for me anyway. When you export the dxf theres a filter option on the screen that pops up. Make sure "tool paths only" is checked.
fullthrottle
Re: cutting problem
Postby fullthrottle » Sat Dec 02, 2017 6:40 pm
Can anyone help with a new problem we are experiencing? Hypertherm 45xp... Starts cutting then stops skips a space then starts back cutting and does this multiple times while cutting the image therefore not able to use image bc it isn't completely cut out. Anyone please help
DaltonMurphy
Re: cutting problem
Postby DaltonMurphy » Tue Mar 20, 2018 10:11 am
i just go back through and delete everything thats not the tool path, make a part, put a tool path on it, well the toolpath runs right through the middle of that solid black line, the programmed line will be on the inside or outside of that solid black line, just delete it the toolpath wont go any or anything, if they are parts u plan on doing again, make sure you SAVE it without any toolpaths on it. always have 2 files for each part. with and without the toolpath, hope this helps.
Return to “Torchmate Software”
