Hey all,
Every time I transfer a file from the Cad/Cam program to Visual Machine Designer it defaults to tool #2. Is there a way in the Cad/Cam program to make it see tool one before I export the file?
If I make a square and export it to VMD it shows the path and will trace the cut with tool #2. If I export a word inside of a box. (I convert the text to graphics, then make path, create tool path, delete the shape, export only the tool path. When I import it into VMD it shows tool paths that look like it's set-up for a cnc router to cut. Shows the tool radius and everything.
Any info on how to get this thing working correctly would be great!!!
Thank you
TorchMate 4x4 growth series
Hypertherm Powermax 65
Lincoln Electric AccuMove 2 / Accumove VFC Controller
TorchMate cad/cam v9
Visual Machine Designer driver software
File transfer from TorchMate Cad/Cam V9
- tnbndr
Re: File transfer from TorchMate Cad/Cam V9
There is another section of the forum dedicated to Torchmate users. You may have better luck posting there.
http://www.plasmaspider.com/viewforum.php?f=53
Also Pirate 4x4 has a forum dedicated to Torchmate systems and there are a lot of members there.
http://www.pirate4x4.com/forum/125-torchmate-cnc-forum/
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
