It is currently Tue Aug 21, 2018 3:50 pm
Help With ShopSabre Controller
jkruse715
Postby jkruse715 » Tue Mar 06, 2018 6:25 pm
I'm new to this forum, new to CNC and new to plasma cutting in fact. I've got a Sidekick 8 from ShopSabre and am running a job. everything stopped in the middle of a job and I'm trying to restart at the line where it quit.
I keep getting the message Error - G28 required for XYZ This is followed by Aborted - EMERGENCY STOP when I try to override, return to Home, etc.
If anyone has any thoughts, that would be great. Thanks!!
fireside
Re: Help With ShopSabre Controller
Postby fireside » Thu Mar 08, 2018 7:15 pm
I had this problem as well, sorry but i don't remember what the fix is but is it is a simple one. Call Ben or Logan at shopsabre they will get you going
ShopSabre Sidekick 10
Enroute 6 Software
Hypertherm PM 85
4th Axis Pipe Cutter
Sidekick Router Package
Eplilog Mini Laser Engraver
Coral Draw 8
Hobart 210 Welder
Columbia Coatings Oven
ScottF
Postby ScottF » Fri Mar 09, 2018 7:28 am
Ben and Logan are great to work with! I am sure you have already but double check to make sure the E stop on the table is not pressed. Rotate it to get it to pop back out if it has been pressed. I believe that is the error message that pops up when you try to run the machine after you press the E stop.
I don't have all the answers but I do have a lot of opinions....
ShopSabre Sidekick 8 with water table
Hypertherm Powermax 85 w/machine and hand torches
IR 5hp 60 gal,+ 60 gallons of storage and aftercooler
Lincoln Square Wave 200
14x40 lathe
JohnnyC
Postby JohnnyC » Fri Mar 09, 2018 7:57 am
You've had better service than me.
