sign weight
sign weight
I am trying to find a way to get the weight of a sign before it is cut. I am sure there is a way to find out how much area there is in the sign but I have no idea what program could tell me that. If anyone knows I would appreciate so information on it. I use CorelDraw X6 but I don't think that will do it.
- WyoGreen
Re: sign weight
If you use Sheetcam, the job report might give you the information you are looking for.
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
- Capstone
Re: sign weight
The place where I buy my metal has the weights of different thicknesses online. You can figure out the thickness and then do a quick calculation with help from the SheetCAM report.
HRS Sheet Weights
Common sign metals...
14ga 3.125lbs per Sqft
16ga 2.5lbs per sqft
HRS Sheet Weights
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
Re: sign weight
I tried in sheet cam but it gives the overall height and width area unless I missed it somewhere. Just to try it out I drew a 48"x96" rectangle with a 36"x84" rectangle cut out of it but it still shows in the report job area 4624.574. I know that would be an easy one to figure out the weight on but when you start adding designs in there that are not square or round it would be a lot harder.
Rodney
Rodney
Re: sign weight
Morning
mild steel weighs .28375 lb/cubic inch.
A number from the past
solomanb
solomanb
- tnbndr
Re: sign weight
In Autocad if you have a closed area, properties will give the area of it. You would just have to add them all up.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
Re: sign weight
I found a macro Cadtool 5 for corel that will tell you the area an then just figure the weight per square foot and it worked pretty good for what I needed. I just needed to let the customer know how heavy it would be before I wasted my time messing with it anymore. It was the biggest I have done so far at 5x10 and 280 lbs my little $400 forklift came in handy. Thanks for all of the suggestions.
