I was looking through the software topics, and there is not a thread for Qcad. Just curious about that.
Qcad came with my table along with Sheetcam and Mach 3. I have also put CorelDraw x7 and Inkscape on my design computer. I'm making slow progress, but have already cut out some neat stuff.
Qcad
Qcad
Eagle Plasma 4x4
Hypertherm Powermax 45
Miller Maxstar 150 SL
Corel draw 7, Inkscape, Qcad, Sheetcam, Mach 3
Re: Qcad
Unless I need dimensional cut pieces with 2D CAD to DXF out I prefer saving as a SVG file for the artwork items. QCAD can save as SVG for Inkscape which can then be used in Sheetcam. I feel DXF has too many problems.
Re: Qcad
.Bigdogbro1 wrote:Unless I need dimensional cut pieces with 2D CAD to DXF out I prefer saving as a SVG file for the artwork items. QCAD can save as SVG for Inkscape which can then be used in Sheetcam. I feel DXF has too many problems.
I recently bought QCAD because I bought some files that were DXF and I could not open them in inkscape. I saved them as a SVG in QCAD, when I opened it in inkscape it was almost unreadable, the lines were super fat. Any advice?
Re: Qcad
I use TurboCad and there is a setting for the line width. Maybe QCAD has one also and you have it set to wide.
In Inkscape you can change the line width under "fill and Stroke" "stroke style"
Re: Qcad
In Inkscape you need to get into the fill and stroke tool. Zoom out and select the entire object. Make the stroke width about .020" wide. This should make it viewable. You may need to rescale the object as well.erik111 wrote:.Bigdogbro1 wrote:Unless I need dimensional cut pieces with 2D CAD to DXF out I prefer saving as a SVG file for the artwork items. QCAD can save as SVG for Inkscape which can then be used in Sheetcam. I feel DXF has too many problems.
Re: Qcad
I'm playing with QCad right now. So far I like it. Only thing is it's not the best for importing SVG into.
In manufacturing, we only used .DXF (original CAD drawings), .DWG (CAM work with tool paths), and .TAP (actual CNC coding).
Re: Qcad
If your referring to polylines, you might want to look at "Create From Segments" (or shortcut: "OG"). If you process through SheetCam, I'm not sure it matters as long as the segments touch.
I don't think QCAD has a Weld command, but could have missed it.
Paul
Paul
