AutoCad 2000
AutoCad 2000
does anyone design parts with Auto Cad 2000?
Re: AutoCad 2000
..........I use TurboCad Pro Platinum 17.3........
Re: AutoCad 2000
how does it work? good for art building also?
Re: AutoCad 2000
As far as vector art, autocad is more technical than artistic, it's great for designing scale projects using existing vector art, not so great for creating vector art, unless you're a whiz at using the polyline tool(s) to draw artistic shapes.
Artistic vector design programs (like corel draw) tend to be a lot faster and easier to work with when it comes to vector art and sign layout type design. Where autocad maintains scientific precision, and has a command for everything, vector art programs let you move, scale, rotate, skew, bend and warp things all over the place with just a click or two and without worrying so much about accuracy and scale.
However, many vector art programs need help when it comes time to export machine friendly DXF files for use in auotcad or cnc programs.
I have autocad but don't use it to create vector art because corel draw/photoshop works better for me.
Re: AutoCad 2000
i use acad 2000i ... mianly because it was the only version i could get running under wine on a linux box. For part design i love acad ... but i've been using it for over 15 years for machine design and structural. For art time stuff i tend to fall back on inkscape and use it's dxf export. then i touch it up in acad if needed.
i dont do too much on the art side.
- plasmajoe
Re: AutoCad 2000
AutoCad is all I use, but you are correct Gary, is mainly for technical design that artistic, but over all the years working with this software I find it works just fine. Yes the other programs out there are much, very much faster that drawing with Cad, but I find most of them are not to friendly for the machine. Lots of nodes, I may be wrong here for I used one one program of the such (BobCad with the Art feature) I really did not like it at all, all the clean up after, I found it easier to draw it out than using that software.SignTorch Vector Art wrote:As far as vector art, autocad is more technical than artistic, it's great for designing scale projects using existing vector art, not so great for creating vector art, unless you're a whiz at using the polyline tool(s) to draw artistic shapes.
Personally speaking, I love AutoCad for everything, but like all softwares, it is what you feel comfortable with so really all in all every program are good, just depends on which one you will spend more time to learn and master.
P.S. Your files that you are trying out the arcs are working very nicelly, I cut out the circle deer you posted as a sample and wow big difference, I will post up the picture as soon as I paint it and install it in my truck.Is your super bundle have the arc optiion on all the files? Let me know please i would be interested in purchasing it.
