It is currently Sun Sep 23, 2018 4:40 am
angle
Post Autodesk AutoCAD related questions and tips in this topic.
Coffinscreekcustoms
angle
Postby Coffinscreekcustoms » Wed Sep 24, 2014 7:04 pm
Ok y'all I'm in 2004 is there any way to draw line at a specific angle? Say 32?
Thanks Jake
AnotherDano
Re: angle
Postby AnotherDano » Wed Sep 24, 2014 7:09 pm
What software are you using?
PCam makes it easy.
Dano Roberts
[email protected]
PlasmaCam DHC-2 v3.11
Hypertherm PowerMax-30
CNCCAJUN
Re: angle
Postby CNCCAJUN » Wed Sep 24, 2014 7:50 pm
1. copy and paste the original line in place
2. rotate the copy line by the needed angle
Simplest method without getting into command line instructions.
There is probably 100+ ways to accomplish what you want in AutoCAD . . .
I always go the simplest route . .
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
Coffinscreekcustoms
Re: angle
Postby Coffinscreekcustoms » Wed Sep 24, 2014 10:49 pm
thanks guys!!!!
stillworkin
Re: angle
Postby stillworkin » Tue Dec 23, 2014 5:02 pm
"snapang" is the command I use a lot of times, although I have a changed the keyboard command to make it easier to use.
once you enter the command it asks you what angle you'd like and when you put your degree in you'll notice your crosshairs change to that degree. As long as "F8" is "ON" (ortho) you can draw a straight line at that angle.
Return to “Autodesk AutoCAD”
