It is currently Fri Sep 21, 2018 1:02 am
text in a arc
Post Autodesk AutoCAD related questions and tips in this topic.
retiredcpo
text in a arc
Postby retiredcpo » Fri Oct 25, 2013 8:04 pm
Anyone know how to make text follow a arc
thanks
Retiredcpo
bhamer62
Re: text in a arc
Postby bhamer62 » Fri Oct 25, 2013 8:16 pm
Newer versions, 2012 and newer, have text on a arc capabilities, but I have not been able to explode text done in that manner to clean it up and make it cut ready. Sooooo....... I do the entire process manually. Takes a little effort but well worth it. Cuts problem free. I would be typing for days to explain how!!! If you PM me your phone no I can call and try to walk you through it sometime. I'm in PA so keep the time zones in mind
retiredcpo
Re: text in a arc
Postby retiredcpo » Fri Oct 25, 2013 10:59 pm
right now I use desk engrave to do the text which is easy but once I import the text to autocad it takes lots of clean up
Not normally a problem but Im doing a custom deal with lots of text in it but im getting it
just looking for a faster way
Gamelord
Re: text in a arc
Postby Gamelord » Tue Oct 29, 2013 1:29 am
If you are using Corel, you can use the 'fit Text to path' command found under the "Text" pull down menu.
To use:
1. Create your text in the size you want.
2. Draw your curve/arc/whatever with the line tool, freehand tool or you can make a circle or other object for the text to follow.
3. Select both the text and the object you want the text to follow.
4. Select 'Fit Text to Path'. The text will move to the object and follow the outline.
5. Adjust with the icons above. You can place the text on top, bottom, slide it side to side, space it out, change how it looks etc...
6. Once everything is how you want it, break the object/text apart, then select the object and delete (if necessary) to leave just the text.
Hope that helps.
Torchmate CAD
Return to “Autodesk AutoCAD”
