It is currently Wed Sep 19, 2018 9:07 pm
explode
Post Autodesk AutoCAD related questions and tips in this topic.
kbenz
explode
Postby kbenz » Wed May 29, 2013 7:31 pm
is there a way to do the opposite? I have an exploded object that i would like to be unexploded. I am using the acad clone of draftsight
CandCNC
Mach3
Draftsight
Hypertherm65 machine torch
Millermatic 210
Spoolmatic 30a w/ WC-115a
Miller Bobcat 225
sodfarmer
Re: explode
Postby sodfarmer » Wed May 29, 2013 7:53 pm
Use the pedit command. It will ask you select a polyline, select the multiple command and select the lines that you want to join. It should ask you to convert to polylines, select yes. Pick join. It will ask you the fuzz distance, I use the default which is 0.0000.Use this and you should have a polyline as long as the lines are connected.
John
kbenz
Re: explode
Postby kbenz » Wed May 29, 2013 9:52 pm
I do good till i hit the fuzz? I'm not gettin that. here is a screen shot. thanks
CandCNC
Mach3
Draftsight
Millermatic 210
Miller Bobcat 225
sodfarmer
Re: explode
Postby sodfarmer » Thu May 30, 2013 7:21 am
Try changing the fuzz distance to .000. I have found that the default distance doesn't work with some files.
kbenz
Re: explode
Postby kbenz » Thu May 30, 2013 8:05 am
crap..........
CandCNC
Mach3
Draftsight
Millermatic 210
Miller Bobcat 225
Return to “Autodesk AutoCAD”
