explode
explode
is there a way to do the opposite? I have an exploded object that i would like to be unexploded. I am using the acad clone of draftsight
CandCNC
Mach3
Draftsight
Hypertherm 65 machine torch
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Re: explode
Use the pedit command. It will ask you select a polyline, select the multiple command and select the lines that you want to join. It should ask you to convert to polylines, select yes. Pick join. It will ask you the fuzz distance, I use the default which is 0.0000.Use this and you should have a polyline as long as the lines are connected.
John
John
Re: explode
I do good till i hit the fuzz? I'm not gettin that. here is a screen shot. thanks
- Attachments
- 1.jpg (90.82 KiB) Viewed 2481 times
CandCNC
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Re: explode
Try changing the fuzz distance to .000. I have found that the default distance doesn't work with some files.
Re: explode
crap..........
- Attachments
- 1.jpg (132.72 KiB) Viewed 2448 times
CandCNC
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
