It is currently Tue Sep 25, 2018 12:01 am
Converting jpg files to pcm files
Illustrator software related questions and tips can be posted to this topic.
JamesMurphy
Postby JamesMurphy » Wed Jul 14, 2010 12:53 pm
I am new to the PlasmaCAM and am having trouble converting from the jpg files to the pcm files. Also, when I try to convert to cut path, everything gets distorted. I've tried using Paint to convert them to bpm files, but they also come out distorted. Any suggestions? Any and all will be appreciated.
Greybear
Re: Converting jpg files to pcm files
Postby Greybear » Thu Jul 15, 2010 10:29 am
Can you give us some specifics about the trouble you are having with your conversions?
Since this is posted in the Adobe Illustrator section, I am assuming you are importing a .jpg file into Illustrator, manipulating it and then exporting it out as a .dxf file, and finally importing into the PlasmaCam software for cutting.
Personally, I don't bother much with trying to convert picture files into cut art anymore. I usually <Place> the picture into an Illustrator document as a template (this way it sits in a separate layer and functions as a sort of pattern), and then use Illustrator to create a new line art drawing from the picture elements. This works out much better and avoids a lot of the cut path problems I used to experience from plain conversions.
If you can detail the steps you are taking to do your conversions, I'll try to give you some tips that may make life easier for you.
- Greybear -
_____________
GB's Fab Shop
Garden City, Utah
Return to “Adobe Illustrator”
