windows 10
- 99guy
windows 10
will x6 run on windows 10 home or pro?
TruCutCNC Series1 Gen2 4x8 water
TruTrac THC
Powermax 85 . M85 Torch
TD A120 . SL100SV1
Mach 3 . SheetCam . CorelX6
TruTrac THC
TD A120 . SL100SV1
- Gamelord
- 4.5 Star Member
Re: windows 10
Yup, no problem. If you upgrade and find that your menu items are gone...its because Win10 uses the same default color for the menu items at Corel uses for it's background. Just change the color and your menu items will become visible again. If they don't dissappear, then disregard this message.
Been using X6 on Win10 for over a year now, no issues.
- 99guy
Re: windows 10
thanks, moved to 10, pretty happy with it so far ...... to my surprise, lol
TruTrac THC
TD A120 . SL100SV1
TruTrac THC
TD A120 . SL100SV1
- Sampson Jones
Re: windows 10
How do you change the color of your menu items ? My main tool bar is only visible when you hover the mouse on the item in the tool bar . Only other problem I had is the dxf tool from lenorad designs dont work anymore .
CandCNC electronics
Hypertherm powermax 65
Command Lineux
Super z 2
Inkscape and corel draw
CandCNC electronics
Command Lineux
Super z 2
- Gamelord
- 4.5 Star Member
Re: windows 10
Right click on the desktop, select "Personalize" from there, you can change everything.
- Sampson Jones
Re: windows 10
Im still not getting it , my tool bar in corel draw only comes on when you hoover the mouse over the tool bar item -example ,file,arrange,edit
CandCNC electronics
Command Lineux
Super z 2
CandCNC electronics
Command Lineux
Super z 2
- Gamelord
- 4.5 Star Member
Re: windows 10
You can change your theme to the high contrast theme and your menu's will show up. this theme is a little annoying for everything else though. If this works for you then just change it back to normal once you exit Corel. If this doesn't work for you, try the below:
Make sure you have the latest update. Go to Help->Updates. With X6, it should upgrade to the latest patch and fix the menu issue. If not and if you have X5 or earlier and don't want to use the high contrast setting you will have to create your own custom menu bar and put it on top of the original one.
Here's a video that shows the easiest way to do that
https://www.youtube.com/watch?v=RycooNWoYb4
- Sampson Jones
Re: windows 10
Thanks Game Lord
CandCNC electronics
Command Lineux
Super z 2
CandCNC electronics
Command Lineux
Super z 2
