Reducing Nodes
ALLOHIO
Reducing Nodes
Post by ALLOHIO »
When I reduce the amount of nodes on my work and save it as a DXF file in coreldraw X3 and open it with my cut and command program for the tracker all the nodes I reduced are back giving me a poor cut.
Start with 356 nodes reduce to 78 save re-open to cut and back to 356 am I doing something wrong?
ALLOHIO
Re: Reducing Nodes
Post by ALLOHIO »
When I save it as a plt then reopen the nodes are back.
20-01 revised_2.plt
(4 KiB) Downloaded 134 times
srp
Re: Reducing Nodes
Post by srp »
The choppy lines could also be because the curve resolution might br set to high in the PLT export. This is found under Advanced tab on the Corel HPGL export. Try experimenting with .1 through .9 or what ever. Compare file size and appearance.
fitzy
Re: Reducing Nodes
Post by fitzy »
try this one reduced nodes using torchmates cad program seemed to smooth it out a bit hope this helps
-fitzy-
20-01 revised_2.dxf
(51.69 KiB) Downloaded 133 times
ALLOHIO
Re: Reducing Nodes
Post by ALLOHIO »
Thanks guys ill give it a try.
ou812
Re: Reducing Nodes
Post by ou812 »
don't know if this helps let me know
20-01 revised_3.dxf
(6.32 KiB) Downloaded 131 times
