It is currently Wed Sep 26, 2018 8:57 am
Powermax 600 Fine cut consumables
TTMotorsports
Postby TTMotorsports » Mon Jul 16, 2018 6:51 pm
I recently purchased some consumables from a supplier online and ordered Hypertherm 220326 as well as 220330 and 120574. I received the 220330 and 120574 but was told the 220326 is discontinued. Does anyone on here have any shields for this or suggestions? Should i cut or bore open a standard shield for the fine cut consumables? Thanks
Re: Powermax 600 Fine cut consumables
Postby plasmanewbie » Thu Jul 19, 2018 10:08 am
I have used part# 120303 deflector in the past (I don't use ohmic sensing), or just mod a standard shield. The shield is not as important when using Finecuts since the amps are lower and material is thinner.
TTMotorsports
Postby TTMotorsports » Wed Aug 15, 2018 3:55 pm
Does anyone have the fine cut settings chart. I can't find it on hypertherms website.
Postby tcaudle » Sat Aug 18, 2018 2:15 pm
Use the ones for the 1000 series. Fine cut can be somewhat trial and error anyway. Start with the parameters on the 1000 fine cut (separate) chart. Adjust as needed . Jim C may correct me but I think the 600 came out before there were fine cut consumables.
TTMotorsports
Postby TTMotorsports » Sat Aug 25, 2018 5:53 pm
Got it up and running and cutting great. I used 120303 deflector like stated but had to rig up a ohmic extension to touch the plate for height control. Working great and can't believe i haven't used fine cut in the past. Just did 116 4x6 plaques with anywhere from 4 to 6 numbers or letters on each with mounting holes. All with same set of consumables and very little dross. Would've taken 3 sets of consumables before easily plus tons of babysitting.
