It is currently Sat Sep 22, 2018 8:52 pm
Can't Control Carriage
montanarose
Postby montanarose » Sat May 12, 2018 12:26 pm
Hello, went to start cutting this morning & machine would not Initialize. I have a PlasmaCam machine ,, Error keeps saying,, Can't Control Carriage Gentry, Check wiring & if carrage is jammed with item.... I did the xyz test & messed with the cables while machine was running & didnt do anything.. Can anyone help,, of course Customer Support is closed on day I finally need them... Appreciate any help,, Thank You...
Re: Can't Control Carriage
Postby jimcolt » Mon May 14, 2018 9:29 am
1. Run the gantry all the way to the back and check that it is not out of square. It should trip the limit switch just before the right side hits the hard stop. If the right side hits first...you will error.
2. Power the control box and computer down, disconnect and reconnect both ends of the parallel cable linking control box to computer and wait about 1 minute, then restart everything.
Generally one of these will solve it.
montanarose wrote:Hello, went to start cutting this morning & machine would not Initialize. I have a PlasmaCam machine ,, Error keeps saying,, Can't Control Carriage Gentry, Check wiring & if carrage is jammed with item.... I did the xyz test & messed with the cables while machine was running & didnt do anything.. Can anyone help,, of course Customer Support is closed on day I finally need them... Appreciate any help,, Thank You...
Users browsing this forum: No registered users and 6 guests
