It is currently Mon Jul 16, 2018 3:01 am
Diamond Plate
john527
Diamond Plate
Postby john527 » Tue May 08, 2018 5:45 am
?? When cutting aluminum diamond plate 1/16", with plasmacam with advanced height control, do I do a test cut to calibrate like I would regular sheet stock?
Gamelord
Re: Diamond Plate
Postby Gamelord » Tue May 08, 2018 11:44 pm
I would. Make sure your settings account for the max thickness of the diamond areas, not just the edge of the plate.
Torchmate CAD
john527
Re: Diamond Plate
Postby john527 » Wed May 09, 2018 5:16 am
Thanks, that's kind of what I thought too.
Re: Diamond Plate
Postby jimcolt » Wed May 09, 2018 8:14 am
Actually, I recommend cutting tread plate (aka diamond plate) with the bumps up, and at the book cut speed and height and voltage for the nominal thickness of the material (not the thickness at the bumps). The Plasmacam advanced height will rise and fall over the bumps very nicely, and you will get great cut quality. Jim Colt Hypertherm
john527
Re: Diamond Plate
Postby john527 » Wed May 09, 2018 1:48 pm
Thanks Jim, I will try this
