It is currently Sat Sep 22, 2018 10:44 pm
Is this going to cut correctly?
michelle
Postby michelle » Mon Apr 30, 2018 5:26 pm
Can someone take a look at this file and tell me if it looks like it will cut correctly? It wasn't right when it was done originally but I 'think' I have it fixed, I just need an expert to check it before I waste more material!
Thanks guys!
Michelle
weldguy
Re: Is this going to cut correctly?
Postby weldguy » Tue May 01, 2018 2:35 pm
Try posting this in the file sharing forum and you will reach more members and likely get the help your looking for. I cannot open pcm files or I would take a look.
michelle
Postby michelle » Fri May 04, 2018 10:25 pm
I cut it and it worked. Thank you!
rdj357
Postby rdj357 » Fri May 04, 2018 11:38 pm
Here you go, I cleaned it up and fixed the unlinked paths out in the middle that were piercing on the path. Bridged in some details in the wings that were fallouts, reshaped the left eye and added a touch of detail, thickened the antennae just a little for strength, and scaled back some open path details that were close to cutting to the edge. I do custom file work if I can ever help - [email protected]
Hope this helps a little!
Robert Johnson
Learn Plasmacam Website
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
Users browsing this forum: No registered users and 4 guests
