It is currently Mon Jul 16, 2018 4:27 pm
Reducing taper on holes
ianhem
Postby ianhem » Tue Apr 24, 2018 5:38 am
Hello
I'm looking for advice on sheetcam to improve my hole cutting 15mm (0.6in) diameter in 8mm (5/16) mild steel plate.
I have an 85amp chinese plasma and a diy table running mach3.
I am new to this and am currently cutting at a speed of 700mm/min (27.5in/min) at 80 amps.
I am getting about a 1mm taper.
I am not sure how to set my tool in sheetcam should my lead in be normal ramp or wiggle?
What is the best way to set up my cutting operation?
Any help is appreciated
East German
Re: Reducing taper on holes
Postby East German » Tue Apr 24, 2018 6:04 am
Hello
You have to determine that yourself for your machine.
Write different test programs and compare the result.
Here's an example.
Peter
Homemade CNC Plasma-Watertable with Mach 3
Triple Beast + Leadschine Drive
Hypertherm Powermax 85
Machine Torch + PriceCNC THC
Hypertherm Powermax 1100
Machine Torch + Proma THC
ianhem
Postby ianhem » Tue Apr 24, 2018 6:53 am
Postby weldguy » Tue Apr 24, 2018 9:25 am
If you have found settings that work well cutting straight lines typically you would reduce your cut speed by 50-60% for small holes and turn off the ATHC. I had a china built plasma when I first started and could never achieve the results I now get with my Hypertherm plasma. Best of luck, hope you get it dialed in!
Postby jimcolt » Tue Apr 24, 2018 10:29 am
send me an email and I'll return a copy of my "Best practices for plasma cut hole quality". [email protected] Jim
ianhem
Postby ianhem » Wed Apr 25, 2018 4:55 am
Jim
I'd like to thank for the information you sent me. It is clear and well presented, definitely helpful.
I must admit I wish my table had a Hypertherm!!
Ian
patrog
Tapers on my cut
Postby patrog » Thu Jun 14, 2018 9:39 pm
I have a 4x4 Arclight table and a powermax 65 hypertherm. I cut some 5" circles from 1/4" plate, they came out good but not sure how to set the machine for the least amount of taper. I was set at 65 amps when doing the cut.
Brand X
Postby Brand X » Fri Jun 15, 2018 2:10 am
45 amps/ book best quality speed Too many amps on .250 for best bevel. Here is some .750 I cut in test strips @45 amps. Was i was bending them on my shop press, and needed to now how much PSI to bend 3/4 ---17 tons.. :mrgreen:
