It is currently Thu Sep 20, 2018 11:08 am
Cutting 3mm stainless steel
Jonplasmaboy
Postby Jonplasmaboy » Thu Feb 15, 2018 6:05 am
Hi all,
Ill be cutting 3mm stainless steel and as it will be my first time cutting this material I'm interested to learn of any tips that will help give me best results.
I have a Hypertherm Powermax 65 with CNC downdraft table.
Any advice is appreciated
Thanks in advance
Jon. :)
Re: Cutting 3mm stainless steel
Postby jimcolt » Thu Feb 15, 2018 11:19 am
Use either the Fine cut consumables or the 45 amp shielded consumables.....follow the specs in the operators manual cut charts exactly (pierce height, pierce delay, amperage, cut speed, physical cut height and arc voltage. These are developed for best combination of cut quality and consumable life. Jim Colt Hypertherm
Jonplasmaboy
Postby Jonplasmaboy » Fri Feb 16, 2018 11:11 pm
Thanks Jim. Took your advice and cutting was fantastic.
Cheers
Jon. :P
Users browsing this forum: No registered users and 5 guests
