It is currently Sun Mar 18, 2018 9:16 pm
First time cutting .375"
Postby DXF » Fri Jan 19, 2018 8:02 pm
A friend of mine hooked his Miller plasma cutter up to my Plasma cam machine because it will cut .500" +. After several test cuts was still having tapered holes using fine tips. Cut nice on the other larger cuts. Can anyone see what I'm doing wrong here by the cut pictures? How high should the torch be when piercing and cutting .375" thick material? Thanks
Dave Hanks
steel 35
Re: First time cutting .375"
Postby steel 35 » Fri Jan 19, 2018 8:44 pm
Don't run a miller but my fine cuts, would be far from proper.
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
