Help finding oem consumables
Whats up! I have an everlast 60s plasma and looking for oem type consumables for fine cut type stuff. i have searched the net and everlast website to no previail. Any help would be appreciated.
Re: Help finding oem consumables
Tecmo makes the torch and consumables .
http://www.tecmo.it/upld/repository/File/02.PT+TH.pdf
There are no "fine cut " consumables for that torch .
Good luck on finding the actual parts listed somewhere for you to buy.
what i meant was a 10-20 amp tip. Im cutting thin stuff and would like a smaller arc (terminology)
Then you are SOL. They don't make fine cut or low current tips for that torch .
Since that OEM manufacturer of your torch is one of the largest after market consumables providers too, you can rest assured that no one else would make it
I don't know the feasibility to mount one of the smaller torches on the 60s.
Looks like they make the tip you want for your PT-60 torch
Tip, Contact Cutting, ø 0.65, 10-20A, Back Striking 51318.06
contact cutting ? what does that mean? It appears its designed as a drag tip. dunno what the "flat tip" version is.
If you look at the machine torch, it shows the same setup. Don't think drag only tip Just need to find one and give it a go.. One thing is a tip might not be perfect for standoff cutting, but sure beats changing a torch out.. Nothing to loose, and everything to gain..
