It is currently Mon Jun 18, 2018 11:10 am
Help with torch installation
Spitterkat
Postby Spitterkat » Thu Sep 07, 2017 5:05 pm
Hi,
I've recently installed the centricut quick disconnect torch (C107-1050) onto the plasma cutter I work with. Everything is installed & is operational, but for some reason it wont initiate an arc when I set the pierce height above 8mm. I'm thinking that I possibly set the torch too low and the THC thinks the torch height is higher? (Using the previous torch, I could set the pierce height to about 12mm, after which point I would have trouble getting the arc to initiate). When I installed the current torch, I marked on the torch body where the previous torch height was and proceeded to install to the same point. I've looked online for instructions on how to set the initial torch height but have had no luck. Do you guys have any info on how to set the initial torch height? and how to get the plasma to pierce at a greater height (one method I read was to have the arc initiate at one height and then set it to go higher for the duration of the pierce? (so that when youre cutting through e.g. 25 - 32mm the spatter doesnt destroy the shield).
Re: Help with torch installation
Postby jimcolt » Thu Sep 07, 2017 6:36 pm
I would suggest speaking with tech support. The height control is not part of the torch, but something obviously changed in the installation.Let them know details about your cnc machine, plasma cutter and height control. Jim Colt Hypertherm
