hyperterm pm 65 code 30-1
Jordf
Post by Jordf »
Hi i have a home built water table with candcnc controls, powermax 65.. When I have longer running cuts, it keeps stopping and showing error code 30-1. Due to crap getting into the tip. Even when my consumables are new!! Its super annoying. Ive tried raising my pierce heights and cut heights, it seems to have helped a bit but the problem still happens at some point.
Any good tips to avoid this? how much higher can I raise the torch over factory hyperthem settings before it causes other problems
