Secrets of Stainless...
davek0974
Post by davek0974 »
Hi all, long time since :D
I have a possibility of a batch job, did a test piece tonight and it was not as good as expected, 3mm 304 stainless steel, disc is 90mm dia.
Part was cut with 3mm over-burn, no torch-off rule, 3mm lead-in, 45A, 3700mm/min.
Even with the over-burn it has left a big tag on the parts???
So, what can i try here, i want them a bit better naturally :)
SeanP
Re: Secrets of Stainless...
Post by SeanP »
Same here on stainless Dave, I don't really do much though, I get that on steel over 10mm and use a slow down rule to catch that tag, 2.5mm before end feed rate 40% (include lead out unchecked)
Might be worth a try, you will probably have to experiment a bit the catch it.
Im keeping away from stainless Lettering, too much cleanup for my liking.
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
davek0974
Post by davek0974 »
Hi Sean, hope things still going well :)
I'll try the slow-down on the next test, I was hoping a 3mm over-burn would do it but it seems to make no difference?
I tend not to use lead-outs on internal cuts as if the waste falls, the torch is cutting in air which blows the nozzle, thats my theory anyway :)
I'll play with slow down.
ajk2004
Post by ajk2004 »
I'm sure you can find several tips on cutting stainless here. One thing that's obvious is that your torch is riding too high, that's evident by the top dross.
davek0974
Post by davek0974 »
Hmm, that's odd as it usually runs at the right height, i'll have to dive in and do some tests i think as soon as i get a break.
Gamelord
4.5 Star Member
4.5 Star Member
Post by Gamelord »
Stainless is quite different than steel. I always use a lead in and lead out when cutting or I end up with what you have there, unfinished cuts and divots. Also, make sure you are going the right direction or you will get increased bevel on your part, usually much worse than with steel. I always get more dross with stainless than with steel....it doesn't actually look that bad on your cuts. Keep running tests until you get what you like. Once you get it dialed in it works pretty good and you can get some good results.
Torchmate CAD
sphurley
Post by sphurley »
Platform CNC Plasma table
CandCNC Ethercut IV DTHC
Hypertherm 85/CPC/RS485
Miller 350P
Miller Dynasty 280DX
plain ol Bill
Post by plain ol Bill »
Yeah, what Jim said if you follow the above post. The tip is CLOSE, .02 when cutting. Pierce it as close as you dare and get the torch down to cut height QUICK.
plain ol Bill
Hypertherm 1250
Duramax machine torch
Corel Draw X6
Mach3
5 x 10 self built table
Lots of ineptitude
davek0974
Post by davek0974 »
Will have to play with this i think, might also try the fine-cuts on it.
Post by jimcolt »
The best cut will be with the Finecut consumables at the cutting specs listed in the Powermax operators manual. Height, cut speed, amperage are critical. Jim Colt. hypertherm
davek0974
Post by davek0974 »
Thanks Jim, i will be "going back to book" with this as soon as i get a gap.
I did try some at the weekend and improvements were found by piercing at 3mm and cutting at 0.5mm &45A on the 45A consumables plus adding a slowdown to 40% for the last 2mm with a 1mm over-burn, no lead-out.
