It is currently Thu Apr 26, 2018 6:39 pm
Help...need a finer detail plasma.
martinmetal
Postby martinmetal » Tue Jan 03, 2017 3:37 pm
I am running a Hypertherm Powermax 85 with machine torch on my cnc table. The guy down the street is kicking my tail with extremely detailed and wirelike cuts. I just can't get that degree of precision when the smallest orifice consumable available is a 45 amp fine cut. I'm looking for advice on which machine I can purchase that can be connected to my table control, has a machine torch, and has consumable fine enough to such detail.
Any advice is welcome.
Thank you,
Travis
mdwalker
Re: Help...need a finer detail plasma.
Postby mdwalker » Tue Jan 03, 2017 11:54 pm
Purchase one like he has........
martinmetal
Postby martinmetal » Wed Jan 04, 2017 9:00 am
Haven't been able to find out what he has.
Does anyone know of a machine with a machine torch and can hook up to my system that can run at low amperage with smaller orifice consumables than the 45 amp fine cut consumables from Hypertherm?
motoguy
Postby motoguy » Wed Jan 04, 2017 9:14 am
Have you tried running at lower amperage with the fine cuts? I haven't yet, but I know some guys run down to 25a with the fine cuts, for very thin kerf. I don't know what their other settings (voltage, ipm, etc) are, though.
martinmetal
Postby martinmetal » Wed Jan 04, 2017 10:54 am
I'm currently experimenting with all different settings now. I'll let you know what I figure out.
Postby jimcolt » Wed Jan 04, 2017 12:50 pm
What material thickness and type, and can you give us an idea of the detail you need? A picture with dimensions, or even a .dxf file would be great. It will be difficult to find a plasma that will have a narrower kerf than your Powermax with Finecuts. Keep in mind that good detail on cutting is a combined effort of motion control, acceleration, cut speeds and height control. The plasma is only one part of the equation.
Some pics of the cuts you are getting.....with your thoughts on the areas that need improvement will help us help you as well. Info regarding your machine, software, height control, etc. will help.
Brand X
Postby Brand X » Wed Jan 04, 2017 1:40 pm
Sometimes you can cheat very thin material by using a water table to control the burn-off of very thin edges.. It just one more tool to use..I agree, it will be quite hard to get much thinner Kerf in Air Plasma then with the powermax systems. You could match it, but highly unlikely to get any better over setting up things correctly. My Esab with 20 amp tips was pretty good, along with my finecuts on my Powermax.. Leaves you Victor, and with work, you can get good detail.. Don't really have too many more good options in Air plasma.. Maybe drag by hand with a low amp plasma cutter..
tcaudle
Postby tcaudle » Wed Jan 04, 2017 4:03 pm
The guy down the street may not be using plasma. Really fine lines could be water jet or even laser cut. There is a finite kerf width when you are cutting with a 30,000 deg arc and blowing it out with shop air.
Users browsing this forum: No registered users and 4 guests
