Cutting over things twice
Rileyj
Post by Rileyj »
:!: I can take a image, vectorize it on hycad, put it on sheetcam with no offset. I put it on Burntables it looks good then when it starts to cut it goes over every cut twice. HELP :?: :?: :?:
Hycad/sheet cam/burntables
sphurley
Re: Cutting over things twice
Post by sphurley »
If you have open paths in sheetcam (you can test it in SC with simulation) it may do that. depends on your open path settings if I recall
Platform CNC Plasma table
CandCNC Ethercut IV DTHC
Hypertherm 85/CPC/RS485
Miller 350P
Miller Dynasty 280DX
sphurley
Post by sphurley »
You only have one layer correct?
Miller 350P
Rileyj
Post by Rileyj »
How do you know where to change the layer?
And should it always be one???
sphurley
Post by sphurley »
I might take a look at ArcLights videos. They do a great job of getting you started.
https://arclightcnc.com/plasma-demo-videos/#
Miller 350P
little blue choo
Post by little blue choo »
Releyj post a file you're having problems with and maybe we can see what going on.
Rick
Rick
Arclight 9600 4x8 table
Gamelord
4.5 Star Member
4.5 Star Member
Post by Gamelord »
If you did a trace, it is possible that you actually have two images instead of one. when you make a trace of an object, you actually trace all the dark areas (black areas) AND the white areas (open spaces). The reason you don't see the white areas is because they are usually layed on a white background with no outline so they don't really show up. When you send to the plasma, it creates a cut path for the black areas and also creates an exact cutpath for the white areas. It doesn't see color, just objects so it see's the black areas that you want and the white areas that you don't know are there.
To fix this you will need to delete all the inside areas (also called drops) so that you are only left with the one single object instead of two.
Hope this helps.
Torchmate CAD
Rileyj
Post by Rileyj »
Thanks for all the help I solved, it was a layering issue. Thanks so much for all the help!!
