Purchasing consumables
Where does everyone purchase Hypertherm consumables? I need a good quality place to get mine from, our purchasing department started buying off ebay and I noticed I was going through tips at an alarming rate.. I can sometimes blow a tip out in 5 minutes
Re: Purchasing consumables
I buy from torchking on ebay and have not had any problems.
I would not buy any that say "after market"
if your loosing a tip after 5 minutes there is something wrong!
I'm sure Jim Colt will be asking you come questions about your operations..
I order from Bakers http://www.bakersgas.com/. UPS man should actually be dropping off more electrodes, swirl rings, 45 and 65 amp tips any moment!
+1 Torchking aka harris supply
Torchmate 2x2 - Flashcut
Powermax 45 - Machine torch
Taig CNC Mill - Flashcut
Razorweld Distributor
- tnbndr
I order the bulk electrodes and nozzles from these guys:
http://hyper4less.com/advanced_search_r ... rds=228843
I order the other parts as one or two to keep around just in case.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
- see&see
Hyper4less is actually R & M Welding Products Inc. and they are a long time Hypertherm authorized distributer. There's been some discussion on this in the past and I've checked them out with the powers to be.. Spend 100 bucks or over and the shipping is free but it's slow UPS ground so allow extra time if you are a distance from Kentucky.. As an example I just ordered the bulk kit of 25 220941 nozzles and it came to 4.79 per nozzle shipped.
You marry into the PlasmaCam family and must accept the fact your software and hardware are proprietary. It's a for better or for worse engagement with overwhelming security. PlasmaCam controls the computer, table, hardware to their advantage IMO.
I'm glad you posted this. I visited their site, and the first thing I thought was "this is sketchy as hell. I'll stick with Bakers.". Lolsee&see wrote:Hyper4less is actually R & M Welding Products Inc. and they are a long time Hypertherm authorized distributer. There's been some discussion on this in the past and I've checked them out with the powers to be.. Spend 100 bucks or over and the shipping is free but it's slow UPS ground so allow extra time if you are a distance from Kentucky.. As an example I just ordered the bulk kit of 25 220941 nozzles and it came to 4.79 per nozzle shipped.
Hello
I use both Hyper4less and Bakersgas and have not been disappointed with either. However because I live in a remote location I don't wait until I am out of consumables before I order. So I plan ahead and keep at least one full set of torch spares on hand and order consumables when I get down to the last retail package on hand. Reality space is that lost time costs way more than the time cost of money it takes to keep your torch supplied with consumables and spare parts.
John
John
- tnbndr
I verified that they were an actual Hypertherm retailer before I ordered. Waiting now for my second order from them. Yes, they send ground slow but I plan ahead.I thought was "this is sketchy as hell. I'll stick with Bakers.". Lol
I've bought mostly from Torchking and Hyper4less and agree with the positive points already posted above. That being said, I can loose a genuine Hypertherm tip with one bad pierce.
PK
PK
- see&see
I need a lot of nozzles but it's mostly due to the parts I cut have a bunch of holes that require numerous pierces. Jim Colt has many posts on bringing pierce height up slightly and it helps a bunch. For example, I use Jim's suggestion when cutting 1/2" with the slower but slightly better quality 45 amp process of a .2 to .25 pierce height and a 1.2 second pierce delay. Even with the 65 amp process I use on 1/2" most of the time I raise the pierce height up slightly to keep the orifice round longer..
Where do you find the settings for 45A 1/2"? All the cut charts I can find stop at 1/4" on 45A.
I cut 1/2" mild steel at 45amps at 17ipm.
For pierce height i used .16 (if i remember correctly) and 2sec pierce delay
Use the powermax 45 for starters.. 17 ipm will probably be too slow for your Powermax 65 using it's 45 amp consumables..
Anywhere between 17 and 20 ipm, cut height at .06", pierce height should be .2" to .25" and pierce delay time should be about 1.2 seconds. This will work with any Hypertherm Powermax45, 65, 85 or 105 (or a Powermax1000, 1250 or 1650 equipped with the Duramax torch) on 1/2" steel plate, using the 45 amp shielded consumables.
Excellent edge smoothness and squareness is the result. Jim Colt Hypertherm
- DesertFabworks
I also use Bakergas they have great prices and ship fast. They set up a discount code for me awhile back here is a link to the info if you want to give it a try I believe the discount is still active: http://www.cncplasmabuild.com/bakersgasandwelding.html
Desert Fabworks LLC
Fort Mohave, Arizona
www.desertfabworks.com
Follow our CNC Plasma Build:
www.cncplasminfo.com
Follow our CNC Router Build:
www.cncrouterbuild.com
+1 on Bakers. Have ordered a dozen times and they have been great.
