cutting copper
jeeplogic83
cutting copper
Post by jeeplogic83 »
Have any of you guys cut copper. I had a Guy approach me about cutting copper He wants 22 ga copper cut. I did a test cut and worked pretty good at 25 amps at 110IPM any body have any other suggestions for cutting. any suggestions would be helpful
jeeplogic83
Re: cutting copper
Hey Leatherhands thanks for the the tips
I cut out 200 different sprinkler toppers and the resolution I was able to achieve in copper was astounding. I don't know what it is about copper but the detail you can turn out is incredible
1- .095 copper
2- 20 amps
3- 125 ipm
4- hypertherm with fine tips
