30 amp settings for a Thermal Dynamics cutmaster A80
scooper
Post by scooper »
I am looking for 30 anp tools does anyone have any or know where i can find them? Thanks!
mlinehan
Re: 30 amp settings for a Thermal Dynamics cutmaster A80
Post by mlinehan »
30 amp cut speed chart:
30A, 1/16" standoff
18ga 240 ipm
12ga 120 ipm
6 ga 40 ipm
1/4" 20 ipm
3/8" 10 ipm
scooper
Post by scooper »
Thanks for the reply how can i also get the Kerf with, Pierce delay, Pierce hight, Plunge rate, Cut hight, Voltage & what the best air pressure to run per material and thickness. Thanks
Post by jimcolt »
Isn't that information all listed in the cut charts in your Cutmaster operators manual?
Jim Colt
scooper wrote:Thanks for the reply how can i also get the Kerf with, Pierce delay, Pierce hight, Plunge rate, Cut hight, Voltage & what the best air pressure to run per material and thickness. Thanks
scooper
Post by scooper »
The cut charts only go to 40Amp
billy55
Post by billy55 »
This is what i use for 30 amp on my A-80 and works fine for 16 and 14 ga .029 kerf width,90 ipm [water table], pierce delay .2,pierce height.06,cut height .05. 95 vlts.
Plasmaroute HD 4x4 TD A-80
scooper
Post by scooper »
Thanks for the help
Little Leonard
Post by Little Leonard »
I run a 82 on my table and the manual is no where near the speeds I cut at or hight
4x8 Precison plasma table
Candcnc
Sheetcam,Mach3
TD cutmaster 82
plumbrob
Post by plumbrob »
I have TD cutmaster 82 and I find the speeds are really close to the book, but my only goes down to 40amps the book that is
