I have a torchmate. having trouble figuring cut inches. I was posting in the pricing thread but decided to start a new post.
I imported a 12" x12" square (48" total right?) my driver came up with .56 seconds cutting. x 60 ipm = 33.6 cut inches. what could I be doing wrong?
cut inches
Re: cut inches
Not sure how that calculated but .8min (48secs) is how long it will take to cut that piece @60ipm
WSS
WSS
Re: cut inches
that's still only works out to 28.8 cut inches?
Re: cut inches
I think what is confusing you is you are seeing the 56 seconds or 48 seconds as a decimal of .56 or .48 when in fact 56 seconds is 56/60ths as a fraction and 48 seconds is 48/60ths which is a decimal of .93 and .80 respectively.
Try a square 15 inches, that would add up 60 inches cut which at 60 ipm would equate to 60 seconds or 1 minute, if it doesn't maybe your system is factoring in pierce time
Re: cut inches
muzza is right
56 seconds * 1 inch per second = 56 inches
.9333 minutes * 60 inch per minute = 56 inches
the machine accelerates and decelerates at each end point, it does not travel 60 ipm (max speed) constantly
so cut time is a function of actual speed (which varies), not max speed, plus pierce and dwell times
Re: cut inches
did a 15" square. came up 1:09 = 65.4 inches. this variance is due to ramp up and down speeds. I am seeing that now.
so how do I get a more accurate cut inch measurement on stuff with lots of curves and turns(artsy stuff)? or am I just stuck with what I got?
thanks
thanks
- runninwild400
Re: cut inches
I have a torchmate as well and had the same problem, for calculating cost I had to figure a cost per minute and use that instead of cut inchs, I actually figure the cost right to the second. I don't think there is a way to figure out the cut inches without loading another program and running the file through it.
Metal-Magic
Metal-Magic
- jmsrbrt
Re: cut inches
I would think figuring cost for pierces and cut inches, would be enough to more than cover, or worry about, the ramping up or down speeds, or dwell. My 2 cents. Bob.
Corel 12, Turbo Cad
TD Cutmaster 51
San Marcos, Texas
Corel 12, Turbo Cad
TD Cutmaster 51
San Marcos, Texas
Re: cut inches
agreed. I'm just gonna keep doin what I'm doinjmsrbrt wrote:I would think figuring cost for pierces and cut inches, would be enough to more than cover, or worry about, the ramping up or down speeds, or dwell. My 2 cents. Bob.
