Just a general question, as I am new to this stuff.
I like to put lead-ins on my DXF files to give a cleaner look. I noticed that people don't do that here on the DXF that is posted. Are most cutting as-is? or adding lead-ins later (which I have done)? Same thing on kerf width (understanding that I am using CNC with plasma, and not a router)?
DXF -- Turn Key, or more prep needed
ColdCreekWorks.com
ColdCreekWorks.com
- BrianMick
Re: DXF -- Turn Key, or more prep needed
Most programs you dont want to do lead ins on one copy or it makes it harder to edit the design later....I put in the lead ins when I am ready to cut
Brain
Brain
www.midwayiron.com
www.midwayiron.com
I've noticed some like that too. i use a nesting program called pronest10 and it automacticly puts the lead in and out on the parts i'm trying to cut so if the parts come in with them already drawn then it will give me a open profile error in turn i have to take them out and let the program put them in
Yes, CLIP ART FILES SHOULD NOT HAVE LEAD-INS OR KERF COMPENSATION
Those are end-user specific settings that vary with the machine, material, and user preferences.
Adding lead-ins makes closed curves open. Adding kerf compensation distorts the outline.
Adding either overrides the end-user's ability to apply their own settings, and some platforms (like engravers and markers and vinyl cutters) don't even need lead-ins or kerf compensation.
